Lost my Telescopic Steering Wheel adjustments - Up and Down
2015 Stingray
Does anyone have experience with telescopic steering wheel issues? Mine will go in and out but as of yesterday it will not go up and down, which is more critical to me for getting in and out? Any thoughts / guidance is much appreciated. 2015 C7 Stingray
Given that you still have the in / out functions, it won't be a blown fuse but, if you want to check it, it's in the rear fuse box ( rear hatch ) and, for a 2015 MY, it should be the number 11 fuse. You could also try disconnecting the negative battery cable for 10 to 15 minutes. This will reset the BCM and may solve the problem. You may have to re-index your windows when you reconnect the battery. If that fails, a trip to an electronics specialist and / or your dealer is probably the next step.
Best of luck
Ross
Best of luck
Ross
I will try those things and report back….Thanks
Sadly the fuse was good, as expected since in and out work and resetting the BCM did not work either. Will give my brother a shot at it if he wants to, ex mechanic, or like suggested off to the dealer it goes. :-(
She’s all fixed up after a new motor was installed for a mere $720! The warranty on the new one is 3 years or 60,000 Kms. It’s done and moving on!
