LED high beam and fog
2012 zr1 centennial
QC
Hi everyone. I would like to replace my high beam and fog lamps with LED. Did someone already did this on there car? Are you happy with the results? What brand did you use?
I want to find something with a similar color as the low beam if possible, not sure I want to install HID replacement kit, I did this on another car but wasn't happy because it take to long to get the high beam
Thanks Stephane
Stephane and DCT I realize it is a different product but I bought a replacement headlight system from Radio Flyer in Michigan for my C5. I could not have been happier with the results, I can actually see at night now, and I know they make a number of kits for not only C5's but 6 and 7's as well. George is a great guy to work with, solid reputation.
Have a look, there maybe something you just have to have.:Biggrin:
What shade of color did you go in the fogs? What k color I think they rate it in. Are they too yellow or too blue? Thx.
Stock low beam colour is 4300k I recall, I think most people go with fogs in the 5-6k colour spectrum to get a little bit of a whiter look. Remember higher temp less bright in general.
Thanks a lot for the help. The ones I'm looking at are 6500 so that should work. Is it necessary to get fan cooled?
The lumens rating will dictate if passive or active cooling is needed. Also if you plan to run fogs full time or just when there's fog. :)
As a guide fan usually needed after 5000lumens.
Lots of products available on the market. Price range is huge so I am wondering if a 49$ kit works or if you better pay 150$ for a kit that need a cooling system? Also I would like to get 4300 ore 5000k, I want them as close as OEM color. I could use HID but the delay for maximum power bothering me. I would like to rely on someone's experience.
Riley, the 5000k on your headlight is for lowbeam or hight?
Amazon.ca have a host of LED's...get the ones that are adjustable (able to rotate light bar) with an allen key for low & highs.
Did my '98 C5 Low & High beams plus back ups...worked great.
Now looking to do the High Beams & Fogs on my C6 in the spring.
I replaced my Hi-beams and fogs with high output LEDS. They Looked great and were very bright, great for flash-to pass, BUT simply do not illuminate the road at all. The OE reflectors are clearly not designed for LED bulbs.
The fogs, were even worse than the pitiful OEs.
I did however retain the DRL Switchbacks...love those!
They remain amber when driving with headlights off, or signaling, but turn white to match the headlights when those are on.
But...like I said, it 'looked' great...
Just before winter hibernation, I installed 5000k 100w halogen hi-beams...and WOW! They're as bright as above, match the HID lo-beams very well, as well as 100w yellow fog bulbs....for that C6.R ALMS and LeMans GT3 look. And this setup really throws out great illumination.
Some may say the housings may get too hot with these bulbs, but I figure its no worse than the resistors behind LEDs...moreover...I don't cruise around for hours with the hi-beams on.
Couldn't be happier...but unfortunately I didn't take a pic of this last setup and the car is still hibernating
Thanks Stephane
I tried to install Low Beams on my C5 but the pop ups remain open and the low beams flicker even when off. Will be putting the original halogens back hopefully everything goes back to normal.
I've installed low beam upgrade, high and fogs LED's from Vette lights and they are great!
I’m thinking of making the same upgrade, are you still happy with them? I’m asking because I’ve read other comments about LED’s for high beams weren’t really that great because of the OE reflector?
