Replaced oil pressure sensor and while I had the intake off replaced the knock sensors as suggested .{old ones worked fine)
Check engine light comes on ,which is caused by the knock sensors according to the codes.
After resetting the codes a half dozen times they reappear consistently after every second start up.
Vehicle seems to run normal.( 2002 convertible )
