Jack Pucks & Wheel Spacers?
Hmmm, sort of agree on the tape, but I'd have to see them first, to decide.
Have also seen some DIY screens made up, that are zip tied in place.
That's a more likely option for me.
Yes, zip tied as well available. I wanted something that looked great, permanent install and high quality with mesh that matched rest of car; ergo, Paragon who make very good, high quality parts. Not the cheapest and takes a while for part to arrive and USD. ACS also makes great corvette products. Not sure if they have this product? They make the best rock/mud guards though - but, not cheap - get what you pay for - much nicer than OEM product - FYI.
Good luck with your search and car.
You can get screens that mount on the outside. I did that.
There is no room for jack stands and a jack under the pucks, no.
I just remembered they make jack stands that work with a jack and the pucks. I'll see if I can find them online. I think you put a part of them between the puck and the jack and once up in the air you slide the jack stands onto that part.
Get your dealer to do it - LOL.
The tape they use is 3M specific tape. It will NOT come loose. Ask me how I know. lol
Yes, I know; but, I like to do things that are a bit harder. Ok not me - my dealer at $150/hr charge. I figure having paid $120K + for the car and poor fine motor skills and lack of desire to DIY - what the hell? Car in there anyway and permanent behind grill install.
Mine are permanently taped in from the outside. They ain't goin anywhere.
These are the ones.
I bought mine from Paragon and dealer installed behind grill when in for service. There are others that use tape which I did not want.
Two cents . By the time you buy them after market and pay a dealer to install them you may as well just order the factory installed ones. I don’t think there is a huge cost difference by any means .
Please ignore my ignorance but would it be possible to place a stout length of hardwood under the frame rail to provide room?
Were not available when I bought, I do not think? In any case, the ACS product is far superior in every respect IMHO. And yes, expensive - I believe approx. $700.00 all in? Worth the money to me: looks - matched black paint work rest of car, look amazing on the car, made of a very hard material and function exceptionally well. I am sure if ordered with the car it would be a whole lot less expensive. If I get another C8 ( E-Ray or Z06) I would order the ACS product. To each his own?
You are absolutely correct sir. I believe that they became available for 2023 . I just noticed that you are 2022 . They wanted $610 for 2023 , probably went up for 24 .
Then, I would definitely get the ones from ACS: much better in every way. If I took a pic 4 U I am not sure they would represent the look & quality properly. U have a 2024 on order? You will love the car - amazing to drive - my 5th vette.
Yes . Quite excited now. It’s apparently going down the line tomorrow. As you can see from my sig , my 1st . I did cringe considering the cost for what they are but did order them. In for a penny….. hopefully keep out the horse flies, we get some as big as baby rabbits. I hate cleaning rads !
The underneath is ... protected (right word?) or lined with plastic to reduce turbulence I guess. ANyway, the pucks stick through the plastic. I've never taken off the plastic to see how close it is to the chassis or whether there even is a subframe.
I would think that the plastic at the outer edge where the puck would mount would be in direct contact with the frame. And yes I would agree that other than for protection from road crap etc that there is an aerodynamic aspect to them being there. Would the “ puck “ mounting points be at each end of the outer frame rail adjacent to the seat location? If so the aforementioned length of, say , 2x4 hardwood although not elegant should do the trick.
