HTC 8'' Kenlowe Fan
2021 c8 corvette
Installation of the 8'' Kenlowe Fan
10 Blade
2500 CFM
My HTC does not have an Engine Overheating Problem, What it does have a cooling issue when the engine is shut down and parked.
Sucking hot air out.
My 2 cooling fans on the HTC C8 stopped working during the heatwave when I was parked with the AC on and engine temp reached 96*C.
By the time I got home the temperature was 85*C, engine off and no cooling fans tripping on, other than the 8'' Kenlowe fan.
My cooling system works like a clock, on engine shutdown the 2 cooling fans will immediately trip on for 3 to 4 min tripping off @ 75*C+/- The 8'' kenlowe will trip on @78*C to 80*C to further the cooling of the engine bay.
From what I've read about this cooling fan issue, it would seem this problem with the failing cooling fans has cursed all corvettes.
My fix on bringing the fans back up and running was to disconnect the NEGATIVE battery terminal for 4 hours and then reconnect. She's back up and running now.
engine temp of 96 C is completely normal while parked with AC on. Further more 100 C engine temp is normal on hot days while driving at city speeds
