Exciting compilation of best C8 exhaust sounds in this video, thanks to Chris Brian. .
If you don't get Z51 for $5900 you can still add the performance exhaust option. It's called NPP and it's $1375. It gives you the same exhaust with the valves that will open and shut depending on what mode you selected. That's the route I went.if you you don't buy the Z51 exhaust on the C8 corvette can you still change the mode that will change the exhaust sound like touring sports and track ?
thanks
It will always be in quiet mode. It cannot be adjusted without adding the NPP performance exhaust option.... unless you go for an aftermarket exhaust system when they become available.thanks for the reply, but if i don't take the npp exhaust can i change the exhaust sound with different mode or it will always be the same sound ?
