Great “Best C8 Exhaust Sounds” Video
if you you don't buy the Z51 exhaust on the C8 corvette can you still change the mode that will change the exhaust sound like touring sports and track ?
thanks
If you don't get Z51 for $5900 you can still add the performance exhaust option. It's called NPP and it's $1375. It gives you the same exhaust with the valves that will open and shut depending on what mode you selected. That's the route I went.
thanks for the reply, but if i don't take the npp exhaust can i change the exhaust sound with different mode or it will always be the same sound ?
It will always be in quiet mode. It cannot be adjusted without adding the NPP performance exhaust option.... unless you go for an aftermarket exhaust system when they become available.
