Getting larger tires for my C4
2021 Stingray HTC
A new question to put out to all of you c4 folks with knowledge.....
I am going to get new tires for my c4.
i have the 9.5 inch wheels on the front and the 10.5 inch wheels on the back...
I was thinking of getting a bit larger tires same as what are on the grand sports
From what i can read about going to the larger tire they would fit on the stock rim. Am i correct to think that....??
the 285/40/17 will fit on a 9.5 to 11 inch wide rim on goodyears specs
the 315/35/17 will also fit 10.5 to 12.5 inch wide rim on goodyears specs
Do i need to do anything to my rims to have them fit properly....I have seen people write about spacers? Why would you use a spacer, what is the purpose?
Thanks for your help with this.
__________________
I have 285's all 'round on my C4 and they fit fine and look amazing. (on stock rims)..... I first talked to Manny about the change and he ok'd it.
No spacers needed provided you retain the stock rims. A spacer is needed to correct an offset difference on replacement rims.
I suspect the 315's will be ok on the rear but check with Manny to be sure.
You can get some idea of what 285's look like in this thread:
http://www.canadiancorvetteforums.com/forums/c4-forum/6162-wheel-wizards-3.html
Colin.
Colin.
What did it cost to get the rims refinished. They look great!
Sent from my iPad using Tapatalk
Don't know where In B.C. you are Rusmac, but for $150 apiece Panther machining in Surrey does a fabulous job. has a great touchless wheel machine too.
Al
Ok good to know. No one around Courtenay does this. Maybe in Nanaimo or victoria. I will check around.
