commercial1
I'm New Here
2 You're 10
Dec 15, 2010
7
Ontario
2004 C5 Coupe
Hey all. Just bought an 04 Coupe in the U.S. Finally got it here, had an ignition problem, got it fixed and finally got plates on it yesterday. The problem is the car is on empty and the gas cap wont open. I cant find the manual release. An words of wisdom.
Open up the center console and maybe the button for fuel cap release is disconnected. If it won't open that way, there is a tab located against the upper trim on the driver's side in the rear compartment. Pull it to manually release the fuel filler door.
