Sears hose clamp (el-cheapo) -- 1
Nice new hardwood flooring----- 0
On my way to pick up my baby this morning decided to do a quick wash of some dirty doggee blankees and it come to the rinse cycle -- Hmmm water sounds a bit loud like it not going down the drain -- sure enough the cheap clamp (see pic) let go and the outlet pipe started to come off.
Luckily I stayed for the end of the cycle as I usually do to be safe and noticed it. It could have had a whole load of dirty rinse cycle water all over my nice new hardwood flooring.
I had about 45 minutes to get things cleaned up b4 I had to leave to get my car.
What a day to start the day.
It ended nicely tho -- with my car back in shape and all fixed up by our good buddy Steve of Finishline in Breslau .......
If anyone has the type of clamp (pictured), you're forewarned that they can and will fail and the hose will gradually work loose and come off.
I changed mine to a proper hoseclamp Pictured and installed) and you'd be well advised to check your to be safe.
I'll be thanking Sears shortly for their foresight in the matter.
I had a nice refreshing swim after to cool off (once I stopped cussing).
THE CULPRIT:
THE REPLACEMENT:
THE CLEANEST LAUNDRY-ROOM FLOOR IN TOWN:
THE CULPRIT:
THE REPLACEMENT:
