Boombastic
Member
2 You're 10
Oct 18, 2012
24
Manitoulin Island
2011 base
Took the new vette to the track to see what India numbers she would put down.. She ran a 12.22 at 117mph with a 60 foot of 1.95. Not bad for almost bald street tires. Saw a Camaro ZL 1 there that ran consistent 12.7 secs. I wanted to line up against him but never got the chance, maybe next time.
Glad to hear that you made it down there Kevin -- Did you have to be real careful out of the hole? -- By the sounds of it, good tires should net you 11's.
I hope to make it there sometime soon too.
Colin.
Yep, had to be easy on the pedal when coming out of the hole. Once I get some sticky tires at Dasilva , I will def try again at that track. I can't wait to see your wheels at that track. It should pull somewhere in the 10s with good traction.
I think it has that potential, Kevin-- Traction again would be an issue as well as experience.
Not sure I really want to get involved with that but wouldn't mind knowing its potential.
I think I'll just assume it could go into the 10's and be done with it. Fewer problems and less expense. unless of course if I can get some sponsors. :D
