Well, good news, bad news [two parts]...
The Vette was Dyno'd, and did an insane 714.62 rwhp // 556 rwtq in 4th gear.
Now for the bad news.
Part one. Three subsequent Dyno's followed from 668 to a low of 629. After reviewing the Dyno graphs it was clear that my air/ fuel mixture was completely messed up - smooth in some areas, jagged in others. So, the Kenny Bell B.A.P needs to changed or checked to see if its working properly.
Part two. They were going to do a few more pulls, so that they could verify some information, when on the fifth pull they heard a "clicking sound" from the charger.
So, the charger has been sent to Vortech to get new guts and I will be ordering a new Kenny Bell B.A.P.
But, I need to say that these problem are due to the fact that, I bought a used kit, that I found out later [after I purchased it] was having problems
. Had I bought a new kit a least the parts would have been perfect.
And to top it off, the new "custom" rims that I bought were not the correct offset.
So, I'm grounded for a few weeks until both situations are corrected. I should get the charger back in two to three weeks and the rims I'm not sure about because after talking to the manufacturer it sounds like they may have to build a complete new set.
On the bright side it looks like the car is going to put out some serious jam. I will be putting a larger pulley on because I don't need to drive around with 700+ HP. I want it in the 605 to 620HP area. These numbers are good enough for 10's all day long.
So, I'll keep you all posted!
Will be interesting to see what numbers you get out of your setup.
A good tune is the key factor.
