Why Were Corvettes Made Of Fiberglass? (And Is It Still Used?) — SlashGear
Early Corvette bodies were all fiberglass, but why did GM go with it instead of steel or aluminum? And does it still use fiberglass in modern 'Vettes?
The C8 Corvette’s multi-layer body structure uses a combination of materials:
• The frame is a welded aluminum spaceframe consisting of stampings, extrusions, castings, and hydroformed tubes, with six large die-cast aluminum assemblies for stiffness and lightness.
• The body structure itself is primarily made of bonded composite materials, including carbon fiber reinforced polymer (CFRP) components and glass fiber composites.
• Key composite parts include a curved pultruded rear bumper beam (carbon fiber), and a three-layer glass fiber composite lower tunnel closeout that significantly enhances torsional rigidity and crashworthiness.
• Body panels are made from a mix of fiberglass, sheet molded composite (SMC), carbon fiber, and aluminum.
• The hybrid composite lower tunnel closeout uses layers of continuous/woven and chopped glass fibers combined with carbon fiber preforms in a vinyl ester matrix, produced by liquid compression molding.
This multi-material approach balances lightweight design, strength, stiffness, and manufacturing efficiency in the C8 Corvette’s body structure.
