Colin,
to bad you can't bend over to clean your wheels !! [g].
what are the 'bed-in' instructions ??
Unless of course you are prepared to elaborate on 'performance' driving.[g]
Tony,
welland
LOL Tony, I try not to bend over for anything. Bad for the back. I bend the knees and crouch.
BTW, since we're keeping each other honest about spelling I must point out an error in your post.
EBC's instructions for Early Use-bedding in:
All EBC brake pads are supplied with a pink/red surface coating stamped with the words "Brake-in Coating". This mild abrasive coating is intended to de-glaze the brake rotor. and assist with fast bed-in of the new pads.
Drive carefully for the first 50 miles assessing the changed brake performance of your new brakes and allow extra distance for any braking needs until the pads become fully bedded and you have acquainted yourself with the stopping power of the vehicle.
During early use, it is quite normal for some brake noise to be observed. Brake squeal or a slight dragging sound from the Brake-In Coating is common and not a safety issue. Brake noise may continue up to 500 - 1000 miles on certain vehicles and is highly dependant on driving style and the rotor condition onto which the pads have been mounted.
Early brake noise is not a warrantable condition and drivers are requested not to contact EBC Brakes querying brake noise until the product has achieved these mileages.
After approximately 200 miles of urban use, using the brakes severely ONLY IN AN EMERGENCY, commence th final bed-in of the pads by decelerating from 60 mph to 20 mph at least 5 times on a quiet safe road environment.
Be careful of vehicles around you and behind you when undertaking this final bed-in.
EBC brake pads are a long lasting performance replacement and their true value and performance will only be realized after the pads have been used for 1000 miles in urban driving.
From another forum:
BED-IN Instructions:
1/ After installing new brake pads, make 6 to 10 stops from approximately 30-35 mph applying moderate pressure.
2/ Make and additional 2-3 hard stops from approximately 40-45 mph.
3/ Do not drag brakes!
4/ Allow 15 minutes for brake system to cool.
5/ After step 4/ your new pads are ready for use.
After reading Keith's link on the subject and taking into account the EBC instructions, I'm leaning toward a moderate long term brake in that will help prevent metal shock.
Seems it will pay off in the long run and help prevent any noises and brake/disc problems.
Thanks Keith for the link.
-------and finally thanks to Manny for expert and prompt service. I'm hoping for at least a few weeks use to allow proper break in before "bedding" her down for the winter months. (yes Riley, a little diff - as you know.
![Big Grin :D :D](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Colin.
