The first question is not whether the car can take it, it is whether you can buy it. There are only a handful of E85 pumps in Ontario and most of them are nowhere near the GTA. If you are not within a reasonable drive of one, the rest does not matter.
Assuming you have a source:
The LS3 fuel system is mostly fine with ethanol. The lines are nylon or PTFE lined and they do not care. What does not like E85 on a 2013 car is the fuel level sender - the contacts sulphide and the gauge starts drifting. On a C6 that means pulling the tanks, and it is not a small job. Same era flex fuel trucks had the same problem, so expect it eventually rather than being surprised by it.
You also need a flex fuel sensor and someone to enable it in the tune. The E38 will run on E85 without one, but only by pulling long term trims to the top of their range, and you get P0171/P0174 on a cold morning plus hard cold starts. Adding the sensor is the difference between "it runs" and "it runs right".
Power: on a stock LS3 it is worth maybe 10 to 15 hp at the top, mostly from the extra timing the knock resistance allows. You will feel less than you expect.
Two practical warnings. E85 absorbs water, and a C6 tank that sits for months with E85 in it is a corrosion risk - these are steel tanks and they are not coated for it. And your fuel economy drops roughly 25 to 30 percent, which usually surprises people more than the power gain pleases them.
If the car gets driven regularly through the summer, it is a reasonable experiment. If it sits from November to April, I would not bother.
