DynamicDucts - Official Launch of our Air Deflectors
22’ C8 Corvette 2LT
NB
Happy to announce the official launch of our C8 Air Defectors, customized for maximum airflow for your C8. StingRay, E-Ray & Z06 ! The ONLY air vent/solution with enhanced airflow and integrated debris/bug deflection.
Available here: DynamicDucts™ - C8 Street Edition
Keep your C8 (Stingray, E-Ray & Z06) running cooler with custom Engineered DynamicDucts™ - an OEM-inspired air-deflection system built for the Stingray, E-Ray, and Z06. Using proven engineering, our DynamicDucts mount seamlessly in minutes to channel cool ambient air into the engine bay, reducing heat soak from headers, cats, and exhaust components.
GM OEM Replacement/Enhancement: GM OEM Compatible Upgrade: Precision-engineered replacement for OEM Part Numbers 85580654 & 85580653, delivering superior fit, strength, and significantly improved performance improvement.
Scoop-Style Air Routing: Innovative deflector design channels with enhanced high-volume airflow to critical hot spots, ensuring even cooling distribution without disrupting aerodynamics.
Honeycomb Grill Guard: added protection against ingesting bugs or road debris
Durable PETG-CF Construction: Engineered from high-grade, corrosion-resistant materials for OEM reliability, blending perfectly with your Corvette's undercarriage.
Bolt-On Simplicity: Installs in under 15 minutes using existing skid plate hardware. No drilling, or modifications required. Straight bolt on using existing skidplate bolts. Perfect for DIY enthusiasts or weekend warriors.
Universal C8 Compatibility: Tailored for all 2020+ C8 models, including Stingray, E-Ray & Z06 variants.
As Seen On:
HorsePower Obsessed:
Brandon's Garage:
GM OEM parts unavailable in Canada !!
DynamicDucts™ Shipping Next Business Day.
