DynamicDucts - Official Launch of our Air Deflectors
Status
Not open for further replies.
22’ C8 Corvette 2LT
NB
Happy to announce the official launch of our C8 Air Defectors, customized for maximum airflow for your C8. StingRay, E-Ray & Z06 ! The ONLY air vent/solution with enhanced airflow and integrated debris/bug deflection.
Available here: DynamicDucts™ - C8 Street Edition
Keep your C8 (Stingray, E-Ray & Z06) running cooler with custom Engineered DynamicDucts™ - an OEM-inspired air-deflection system built for the Stingray, E-Ray, and Z06. Using proven engineering, our DynamicDucts mount seamlessly in minutes to channel cool ambient air into the engine bay, reducing heat soak from headers, cats, and exhaust components.
Key Features:​
GM OEM Replacement/Enhancement: GM OEM Compatible Upgrade: Precision-engineered replacement for OEM Part Numbers 85580654 & 85580653, delivering superior fit, strength, and significantly improved performance improvement.
Scoop-Style Air Routing: Innovative deflector design channels with enhanced high-volume airflow to critical hot spots, ensuring even cooling distribution without disrupting aerodynamics.
Honeycomb Grill Guard: added protection against ingesting bugs or road debris
Durable PETG-CF Construction: Engineered from high-grade, corrosion-resistant materials for OEM reliability, blending perfectly with your Corvette's undercarriage.
Bolt-On Simplicity: Installs in under 15 minutes using existing skid plate hardware. No drilling, or modifications required. Straight bolt on using existing skidplate bolts. Perfect for DIY enthusiasts or weekend warriors.
Universal C8 Compatibility: Tailored for all 2020+ C8 models, including Stingray, E-Ray & Z06 variants.
As Seen On:
HorsePower Obsessed:
Brandon's Garage:
GM OEM parts unavailable in Canada !!
DynamicDucts™ Shipping Next Business Day.
Have you tried adjusting the ironing to get the surface of the print smoother?
The Surface prints brilliantly over 95% of the Ducts. The underside of the overhang is where the blemish is. It doesnt affect the parts at all in any way, nor can you see it once installed. But I aim to sort it. PETG-CF is notoriously bad at printing smooth overhangs, and these are very complex parts/geometries.
Currently, it takes 7.5 hours to print a set. I have been messing about with orientation, variable layer heights, smoothing, fans, print speeds (outer/inner) and near every other setting you can imagine. Ironing is on my list also.
try adjusting the ironing and step down to 0.2mm nozzle if CF can take that. with bambu black friday sales you can get a few more p1s printers for cheap for your business.
The ironing typically doesnt work too well on the underside of an overhang. But certainly going to mess about with it. I'm currently running 0.20mm nozzle settings .. and Slowed way way down as PETG likes it slow.
I have 14 printers running now, Black Friday is my enemy ;)
Morning,
It is something I considered, and messed about with, but we made a move to PETG-CF and are print perfect now. The parts/angles/supports/speeds/temps are complex but after some time, we got there and are extremely happy with the results.
Now 500+ sets in circulation, outstanding feedback from quality to performance .... and a manufacturing process to support.... I'm onto engineering our next product release for C8.
I always love the feedback and ideas, much appreciated. Certainly gotten some great feedback and ideas over time from others in the know!
Thanks,
D
Status
