Diy- brake caliper painting??
2006 C6
I have a C6 Z51, so the calipers are already painted ( powder coated).
Has anyone here painted over the powder coating, and if so, how did the paint last. I'll be using high heat paint on the calipers.
Thanks for any help :driving:
[/IMG]
POR has some good paints along with a good primer to make sure the new paint sticks to the old. You can brush it on and it smooths out nicely. I sprayed the underside of and el Camino that I did and it came up looking factory fresh. I brushed the Chevy orange on a cast iron intake and it too looked great. Stop Rust with POR-15
I have painted my calipers with Krylon rattle paint
I paintdf over the word Corvette then took a stiff sanding pad and went over the Corvette word and it came out great.
I have painted my old tahoe calipers and they never peeled or came off.
I sprayed them with brake cleaner first then painted them
Never had a problem in 3 years
Did mine 2 summers ago and they still look perfect. I removed the calipers, cleaned them will with brake cleaner and then painted them with caliper paint and clear over. I don't remember the brand but got it at Canadian Tire. Put vasoline on the raised letters with a qtip before painting, and it is easy to wipe off after.
Yours look great.
I bought the caliper painting kit from CTC as well, which includes the cleaner and paint.
I prepped and did one of the back calipers in Red, and it turned out really nice.
I'll finish the other over the winter.
Thanks for the Vaseline tip for the letters on the front calipers.
If you use a firm fine grit sanding block to remove the paint , it brightens up the word Corvette and leaves a nice sharp edge between the paint and the letters.
