I did my truck headlights with whitening toothpaste, Crest I think , using a buffer. Worked very quickly and they look like new . Just mask off the surrounding area with a couple layers of painters tape and your good to go . Then if you have some put some ceramic coating of some type on to seal the surface.Try tooth paste, and elbow grease (or a buffer)
See post #6 ........hello all
does anyone have any information on how these can be fixed, repaired, replaced....etc?
greatly appreciate any help
thanks
simmer
Thanks appreciatedI did my truck headlights with whitening toothpaste, Crest I think , using a buffer. Worked very quickly and they look like new . Just mask off the surrounding area with a couple layers of painters tape and your good to go . Then if you have some put some ceramic coating of some type on to seal the surface.
PPF on mine and it has a couple of small nicks in it but the lens is fine . Shudder to think what a new headlight assembly would cost....... Wonder no more...... ouch.If they come out good after polishing, apply PPF film on them, that will give you 2 protections, first from rock and debris and second from sun damage. A detailing will offer you these services, the film will cost a little more but still the best result. You can by replacement lens but it is a way bigger job.
