Classic warbirds and other aviation vids.
See 3178 .
I did, but there was only the b&w picture of the military version on the ground.
It has since "filled in" with additional images and text.
Odd. Were you editing it because the image said it was "3 minutes ago" old.
They used something like this to help rebuild some part of the old Oakville Ford Plant's power plant back around 2000.
Stopped/slowed traffic on the QEW for miles as rubber neckers wanted a look.
Check again. It’s above your first reply. I added it as an edit to my original post #3178 . I added it because you were curious as to what it was. Ghost in the machine perhaps. ;)
One was also used during installation of the top of the CN Tower. I remember watching it on a walk down Yonge on my way to Ryerson.
The Atlas Cheetah is a South African fighter aircraft designed and produced by the aviation company Atlas Aircraft Corporation (later Denel Aeronautics). It was developed at the behest of, and principally operated by, the South African Air Force (SAAF).
The Cheetah was developed amid the Border War of the 1980s as a major upgrade of the French-built Dassault Mirage III fleet operated by the SAAF. The programme integrated technology from the Israeli-built IAI Kfir, which had been derived from the Mirage 5/IAI Nesher. The upgrade programme, which was known as Project Cushion, produced three variants; the two-seat Cheetah D, the single-seat Cheetah E, and the single-seat Cheetah C. All three models were inducted into the SAAF, functioning for a time as the service's most capable fighter and strike aircraft. A single Cheetah R, intended for aerial reconnaissance, was built as a prototype, but this variant never entered service.
During 1992, the Cheetah E model was withdrawn from SAAF service; both the Cheetah Cs and Cheetah Ds were retired during April 2008, having been being replaced by the Swedish-built Saab Gripen.
The Grumman JF "Duck" was an American single-engine amphibious biplane built by Grumman for the United States Navy during the 1930s. The J2F Duck was an improved version of the JF, with its main difference being a longer float.
Design and development:
The Grumman JF Duck was manufactured from 1934 until 1936, when production switched to the J2F Duck and later variants. The more obvious external appearance clue to distinguish a JF from an early J2F is the deletion of the inter-aileron strut between the wings on the J2F; less noticeable perhaps is the J2F's slightly longer rear fuselage/float joining fillet beneath the tail.
The Duck's main pontoon was part of the fuselage, almost making it a flying boat, although it appears more like a standard aircraft with an added float. The XJF-1 prototype first flew on 24 April 1933 piloted by Grumman test pilot Paul Hovgard.
The JF-1 that was first ordered had the same Pratt & Whitney R-1830-62 engine as the XJF-1 prototype. The US Navy ordered 27 JF-1s with the first Ducks delivered beginning in May 1934 to Norfolk NAS. These early production series had provisions for mounting a machine gun at the rear seat facing aft, as well as a single bomb rack mounted under each wing, capable of carrying a 100 lb (45.4 kg) bomb or depth charge on each. The main float was also a Grumman design (Grumman Model "A") and like the prototype, it included retractable main landing gear, making the Duck a true amphibian. Ducks served as general/utility amphibians for photographic, target-towing, scouting, and rescue work.
The Lockheed XFV (sometimes referred to as the “Salmon") was an American experimental tailsitter prototype aircraft built by Lockheed in the early 1950s to demonstrate the operation of a vertical takeoff and landing (VTOL) fighter for protecting convoys.
The Lockheed XFV originated as a result of a proposal issued by the U.S. Navy in 1948 for an aircraft capable of vertical takeoff and landing (VTOL) aboard platforms mounted on the afterdecks of conventional ships. Both Convair and Lockheed competed for the contract but in 1950, the requirement was revised, with a call for a research aircraft capable of eventually evolving into a VTOL ship-based convoy escort fighter. On 19 April 1951, two prototypes were ordered from Lockheed under the designation XFO-1 (company designation was Model 081-40-01). Soon after the contract was awarded, the project designation changed to XFV-1 when the Navy's code for Lockheed was changed from O to V.
The XFV was powered by a 5,332 hp (3,976 kW) Allison YT40-A-6 turboprop engine driving three-bladed contra-rotating propellers. The tail surfaces were a reflected cruciform v-tail (forming an x) that extended above and below the fuselage. The aircraft had an ungainly appearance on the ground with a makeshift, fixed landing gear attached. Lockheed employees derisively nicknamed the aircraft the "pogo stick" (a direct reference to the rival Convair XFY's name).
When it comes to military aircraft, few inspire as much controversy as the V-22 Osprey. Developed by Bell Helicopter and Boeing Rotorcraft Systems, the V-22 has long promised a new frontier in aviation — a tiltrotor aircraft that marries the vertical takeoff and landing (VTOL) capabilities of a helicopter with the speed and range of a conventional airplane. However, the journey towards realizing this promise has been fraught with developmental challenges, criticisms, and tragic accidents, leading some to label the Osprey a white elephant of military spending. Nevertheless, as we witness the continued evolution of the Osprey and tiltrotor technology, we cannot ignore the paradigm shift it represents in military aviation.
US Coast Guard personnel prepare to repair a PBY-5A Catalina flying boat in the frozen bay of Kodiak Island, Alaska in 1943. Slow but sturdy and literally indestructible, the Catalina served throughout the war as the air surveillance/recon main platform for the Coast Guard.
Shrinkage!
The Eurofighter Typhoon is a twin-engine, canard-delta wing, multirole fighter. The Typhoon was designed and is manufactured by a consortium of three companies, Alenia Aermacchi, Airbus Group and BAE Systems, which conduct the majority of affairs dealing with the project through a joint holding company, Eurofighter Jagdflugzeug GmbH, which was formed in 1986. The project is managed by the NATO Eurofighter and Tornado Management Agency, which also acts as the prime customer.
