Carmakers can legally record your texts, calls, rules judge
Seattle-based judge rules automakers collecting data via car infotainment does not meet threshold for privacy violation under state law
Much like our combines now. JD newer rigs especially tracks every acre you combine, speed you go and quantity you harvest... Big Brother for sure...Found this. There are several other tutorials that show basically the same thing. Not sure where the module is located in the C8 but it can’t be that hard to find.
How To Disable OnStar GPS Tracking With 11 Detailed Steps
Do you know how to disable OnStar GPS tracking to keep your privacy after discontinuing the service? Here's your step-by-step guide. Let's follow up!bryansgarage.com
I used to encounter this with generators the last several years that I was contracting . The newer units had gone to ECM type controls with a proprietary interface connection and proprietary software which of course you had to connect a laptop running the software to troubleshoot or “ reboot “ the control firmware. So that works really well when they are installed in a remote location in the far north hundreds or thousands of kilometres from any road. Only option is to fly in one of the manufacturers techs at ridiculous cost for the simplest issue.Much like our combines now. JD newer rigs especially tracks every acre you combine, speed you go and quantity you harvest... Big Brother for sure...
Is this happening in Canada and is it legal here?
Found this. Apparently the setup has changed since the C7 . It appears that there is no longer the “ box” with the three cables connected. Looks to be a pain to deal with.Has anyone removed this from our OnStar yet?
The antenna or the module.Removed what exactly?
You need to disable/remove smart driver on OnStar but be aware that if you bring your car into service it will be re activated most likelyRemoved what exactly?
You bet they are. It’s been proven. Nobody reads the EULA . For anything, they just click on install in the case of software for example. Caveat Emptor . This is the GM privacy policy from 2023 , the most recent version I could find, and I doubt it has improved. Read it and weep.On a personal opinion basis only….I would be surprised, even shocked, if it wasn’t going on. Generous Motors Canada is known to be able to squeeze a nickel‘til the beaver defecates. Even if they don’t sell my data, I don’t se why I should allow any company (or government) to keep their eyes on me as a law-abiding citizen.
I'd just remove the antenna. It will not work without the antenna.Found this. Apparently the setup has changed since the C7 . It appears that there is no longer the “ box” with the three cables connected. Looks to be a pain to deal with.
On the U.S. corvette forum search for how-to-remove-onstar-the-right-way
Agreed. Most likely a permanent solution. I would retain the daughter board though in the event of unforeseen issues. That’s the dilemma with On Star though, it can or could be very useful to some in certain circumstances but way too intrusive and outright creepy to me.Gilles27 said: You need to disable/remove smart driver on OnStar but be aware that if you bring your car into service it will be re activated most likely
After briefly reading through the step-by-steps from the url/link 1stVette posted, which actually involves removal of the circuit that houses/controls OnStar, I don't think they'd ever be able to just willy-nilly reactivate it, since the procedure to completely remove that surveillance system requires the removal of the OnStar dedicated "daughter board" from the larger printed circuit board. Even if a dealership actually noticed the disabled OnStar (unlikely bordering on just plain improbable) they'd have to (1) requisition and receive a new daughter-board (2) have a tech spend high-cost shop time to install it with a zero possibility of recouping that cost from the customer for the labour and materials.
True, or in an accident situation in an isolated area for example but as far as theft goes third party tracking is available but the good ones are subscription based but then again so is On Star . At least the third party solutions aren’t spying on you. Or at least not to the extent of GM . What’s really annoying to me is that the issue exists at all. You can start the car with the fob without On Star to the best of my knowledge , or can you not ?The antenna or the module.
I'm 50/50 on whether I'd want to remove it. OnStar could help in case of a theft of the car.
Once a month a female voice tells me it's limited.
You have no choice as you are paying for it in the price of the car. You might as well use all the features like starting the car from your phone etc.
You can. I can't remember all the benefits of the "forced on 2024+ cars", but you can check tire pressure etc. also.. You can start the car with the fob without On Star to the best of my knowledge , or can you not ?
I installed the my Chevrolet app , punched in my vin and all good, got the welcome bit and immediately it asked for my precise location, lol . So I declined and it brings up the main menu and I tap on location ( of the vehicle I assume) of course it says press the On Star button. Not happening. I am digging out my multi screwdriver set and soldering iron if necessary preparing for delivery. Tire pressure and temperature can be selected to display on the main screen I believe and surely you wouldn’t need the Spyware enabled for that.You can. I can't remember all the benefits of the "forced on 2024+ cars", but you can check tire pressure etc. also.
To me it's all gimmicks which is why I didn't even take the free trial. I hate OnStar.
On my 2014 Malibu when you cancelled it a voice came on the radio LOUD stating OnStar was disabled (or some such) EVERY time we started the car! It took several angry phone calls and escalations to get it (OnStar?) disabled (I hope) lol.
Yup, that's why I say it's all gimmicks.Tire pressure and temperature can be selected to display on the main screen I believe and surely you wouldn’t need the Spyware enabled for that.
Since everyone else appears to be talking C8 module, I will answer your question. The C7 module is locate behind the glove box. Rumour has it you need to remove the kick panel, get your head down on the floor and look up. Hope that helps.I've got a 2019 'Ray, and I can tell you that I've searched (and searched, and searched) for that OnStar puppy for quite a while, and haven't found it anywhere. I was initially told it was at, or near, the connection box at the battery cubby, or located next to the rear wheel well(s). Nope, didn't find it. Has anybody ever actually found the OnStar module on a C7, and if so can I get pointed in the right direction. And if anyone has a pic of the actual module where the wiring connector harness plugs in, that would be great - maybe I've seen the thing, but didn't recognize it. My previous daily driver, a Terrain, had it located to the left rear of the spare tire well, and it was marked with the OS logo. Easy to pull the plug, so to speak.
