There is no issue if you leave the switch on auto.This is my first time in a recall with my C8. It must of been a few because my lights always worked well. I guess they recall them all.
Don't apply logic to this thread Murr...Does everyone know about this site?
Put you vin after the =
experience.gm.ca/en/ownercenter/recalls?vin=
You can, in settings, have the system recalibrate the tire pressure monitoring. Just have to dig around. Can’t remember exactly where it is right now……Ok, so drove the C8 today and tires recalibrated, so everything is working fine. The tile thing helped and Murray was right, a few more Ks did the job, adjusting itself.
The recommended pressure at ambient is 210 kpa which is 32 lb/sq in and change. Problem with keeping it consistent is that there are so many factors that affect it . You can see a20 kpa difference from one side to the other for example when one side is exposed to the sun when parked outside. Personally I always go with what the GM engineers recommend.That recommended tire pressure on my door says 32 all around but I haven't adjusted anything yet since I bought the car it's showing 186 cold so I think if I put 32 it'll go up over 2 20 when hot and cause a rough ride so I think I'll go 29 lb cold cuz 32 is the maximum recommended cold pressure maximum
I'd say "not". I think GM and Michelin knows a tad more than he does.Yes however that's irrelevant is he correct or not
