As with the C7 it appears we should not be afraid to get one side WAYYYY up and then the other. Sure makes ramps look obsolete but I cringe at the thought of what could happen when you are jacking the second side up if the first side on the jack stands slip. Jake, do you have rubber caps on your jack stands? Would this be safe with Hockey Puck jack pads? Also how high is it off the ground under the floor pan?
Nice pics. Thanks for the encouragement.
