Has anyone s C8 alarm gone on for nothing? Mine has gone on 3 time, in the last 15 minutes and it's in the garage!
Rogue bunnies eating your wiring?Has anyone s C8 alarm gone on for nothing? Mine has gone on 3 time, in the last 15 minutes and it's in the garage!
Can't see why. I drove it outside and opened and closed all doors hoods and top.Rogue bunnies eating your wiring?
@DenisC8 mentioned not long ago he received a notice from OnStar saying that there was a theft attempt on his car and it was safe and sound in his garage. He may have more information…Has anyone s C8 alarm gone on for nothing? Mine has gone on 3 time, in the last 15 minutes and it's in the garage!
My gyro has been a bit sensitive lately but increasing my fibre intake seems to have helped….Sensitive gyro ? If it happens again .... bring it in .....
You are right about the first part. And it wasn’t from this.You will not believe this but I think it was a fly, inside the car. Nothing else, makes sense.
It happened yesterday around this timeYou are right about the first part. And it wasn’t from this.
Today's Earthquakes in Quebec, Canada
Quakes Near Quebec, Canada Now, Today, and Recently. See if there was there an earthquake just now in Quebec, Canadaearthquaketrack.com
It says 0 earthquake in the last 24 hours. I read, in another forum, that the alarm is very sensitive. Even extreme heat can cause it to go off. Anyway it hasn't happened in the last 24 hours. Problem solvedIt happened yesterday around this time
Ah…that’s why I posted the link. Figured check one extreme to the other.It says 0 earthquake in the last 24 hours. I read, in another forum, that the alarm is very sensitive. Even extreme heat can cause it to go off. Anyway it hasn't happened in the last 24 hours. Problem solved
Welcome to the forum Frank! Thanks for the info and great to know you got it fixed!Mine started doing it all the time and having a rear access open alarm on a regular basis, The soft close mechanism which has a built in sensor
was replace under warranty, all is well now
