C4's please check in
Your C4' (s) -- multiple choices possible
  • 5.7 L (350 cu in) L83 V8 (1984)
    Votes: 11 7.5%
  • 5.7 L (350 cu in) L98 V8 (1985-1991)
    Votes: 87 59.2%
  • 5.7 L (350 cu in) LT1 (1992-1996)
    Votes: 33 22.4%
  • 5.7 L (350 cu in) LT5 (1990-1995)
    Votes: 8 5.4%
  • 5.7 L (350 cu in) LT4 (1996)
    Votes: 9 6.1%
  • Total voters
    147
1992 White on Aqua convertible LT1 automatic with FX3.
Love it like crazy!
R
Here's my '86 Automatic. Low mileage car, actually swapped my '93 40th anniversary Black Rose 6-speed coupe for this one. That was a wicked car, but pretty rough cosmetically. Was one of fifty ever built with the equipment it came with. Miss the slushbox, but this one is a smooth cruiser! And, oh yeah, I'm 62.
Mine is a 1985 C4. Jet Black with grey interior. 4 plu 3 Doug Nash. L98. 2002 wheels and new General Tires. Just took a nice cruise through Litchfield Hills with wife. Had to bundle up. Had top off. I'm 65 and retired from Security. Actually looking for a full-time teaching job. My C4 runs like new after sorting it out for the past 2 years. When I got it all bushings underneath were replaced and new Magnaflow mufflers installed. It needed a radiator, several coolant flushes, tune up, shifter, E Brake light switch, U joints on 1/2 shaft, valve covers and Felpros. This car gets a lot of looks and I feel I'm driving a $100,000 car.
Any troubles with your 4+3? I avoided buying a Vette with one, as I read about all the horror stories of overdrive failures and badly leaking seals, expensive teardowns and repairs. I saw a Vette in quite good shape, but steered clear after learning the car was disabled with a trashed DN transmission, hence the low price. Due to the massive problems with this gearbox, GM hastily cut a deal with the German company ZF Friedrichshafen AG , who manufactured the 6 speed, quite an impressive and reliable transmission.
Really nice ride! Love those wheels, had them on my '93, thinking about getting some for the '86. I just flushed out my rad and put new anti-freeze, but also added a bottle of Royal Purple coolant additive that really works. Knocks down the temp by about 20 degrees.
Very classy silver "86 you got there. The 86 has quite a bit more HP than the 85 and offers the 6spd. A nice upgrade.
Thanks for your reply. I have always been trying to find way to have my car run cooler. How does that royal purple make the car run so much cooler?
I wonder what it is doing chemically to the coolant to get such a result.
I had to keep flushing my cooling system around 6 or 7 times, when I first got the car, to get all of the rusty water out. I now with Prestone 50/50 and a new stock radiator and cap average about 185 degrees. At 203 degrees the electric fan comes on.
OK Happy Motoring
I wanted to post a note on installing a performance chip on a 1985 L98 Doug Nash 4 + 3.
Hello C4 Enthusiasts,
Lately, I thought I'd install a performance chip. I have used "Hypertech" chips in Porsches in the past and they made a big difference. I ordered a chip from Eckler's Corvette , whom I usually have good luck with, but this time the hypertech chip did not work as far as my mechanical abilities are concerned. I couldn't even experience the difference in the torque curve or any of the other so-called exciting factors of a performance chip because the flippin' hypertech chip part # 155371 does not fit correctly into the ECU. The Hypertech chip has extended plastic teeth on both sides. The original Delco Chip also has them however they are approximately 1/16 of an inch shorter so the metal prongs of the chip extend about 1/16" from the black, plastic teeth.
Eckler's did not send me the wrong part either because I went to the Hypertech website, mentioned year, make, and model and the same Hypertech part number was listed.
Thanks For Your Input,
Sharkface
Eddie
Sharkface, just a suggestion. Can you possibly carefully cut back the plastic from the edge of the teeth, thereby exposing the prongs, or will this cause another problem?
It will run in 1 position only, if the chip is installed backwards, the car will not get proper feedback and not fire.
Black Rose is an awesome color. It's pretty warm here today, I'm going to hop in my black shark and go get some chains for my saw. Hopefully I can diagnose a thump I heard last I drove it. It sounds like a loose shock but everything under the car is new and tight.
As far as the hypertech chip goes, I returned it. I could have made it work if I melted the plastic teeth down 1/6 of an inch. From past experience, these chips don't make that much difference and they are bound to make the car run hotter. which is a problem in the 85 anyway.
