Jun 21, 2019
36
31
Getting close to putting the body back on the chassis, so pressure washed the underside, so pulled the console as I am replacing/rebuilding the e-brake and shifter.
Was wondering what people are using for an undercoat, it seems to currently be a mix of 2 paints and some textured undercoat.
Should I be changing the back two mounts, this is the worst looking one.
When I pulled the console apart I found ( besides the mouse nest ) this mess of wires, green, gray and white, look to eventually go to a relay that have been cut. Thinking it may have something to do with the electric antennae?
Can't seem to find the antennae on the diagram.
Thanks for the feedback, George
Hey George. One thing I found that works incredibly well is brush or roll on POR15 and then hit it with zero rust black aerosol after and hour or two. I tested this vs just POR15 and just zero rust and this holds up to hammer strikes. Makes a super smooth satin/flat black finish that almost resembles powder coating. I like to let it dry 24-72 hours before installing parts but it's not a huge deal if you do it sooner.
I know your probably planning on it but getting some new rear body mount supports would be a good idea. I got mine powder coated just to prevent any future issues.
definitely POR15 using their process to the letter. I have used this product several times. If you do not follow their instructions, it will not bond properly. Fortunately for you with the body off, it will be a breeze. I just did this with the body on my 77, and I can tell you at my age with my injuries, it was incredibly tough on a guy.
In a nutshell, you need the frame superclean but not rust free. If you need to grind, and/or have fresh metal repairs, its fine, but POR15 bonds best where rust is present. Even just surface rust. Once free of dirt and flake rust, you use their cleaning solution, then rinse. Then use their metal prep solution and wipe off, which when properly done will leave a sort of white powdery texture on the metal. Then brush or roll on the POR15 .. let set for the required time, and do another coat. Then let it bond. The results are worth the effort.
