AvalonKing Boost spray
C8 2lt HTC
AS you all know, Im an avid fan of these products.
Now its a Boost spray with 20% ceramic in it. Much greater than others.
I got a bottle but it`s too cold out to try on my C8. So I`m testing on 2X winter wheels on the Lexus ES.
Passenger side has it ( so the wife can see), driver side no Boost so we can fine out if it works this winter.
Applied in garage with 40 degrees F temp.
Used about 1 teaspoon for both front and back with a small piece of microfiber cloth @ 3 times.
one to apply, 2 to wipe around, and 3 to buff.
At this temp , I did not have any buffing issues and no haze.
The wheels are shinning and slippery !
I did not try some on my C8 because, as you know, she is very sensitive to cold weather
copied from detail forum to make it easier.
Remember, it`s best to use these detailing products at room temp in shade. If your C8 is blessed with a heated garage or your bedroom, good for you.
I will not be responsible if you use detailing products if the wheels fall off or car won`t start.
And a merry xmas to you Mr. C8 man
