I had to fix a block heater issue on the GF's Mazda CX-3 about 2 weeks ago, needed the element replaced and the part is in the stupidest place that they could put it in to the block (basically underneath the exhaust manifold with barely any room to put a ratchet on the socket when you want to unscrew it). I got the job done however getting a shallow socket along with a stubby ratchet but it was still a bear to do (stubby handle on the ratchet didn't give enough leverage to loosen and tighten the element along with the space issue).
I looked around to see what I could've used to make the job easier to do and I'm sure tools will always come in handy down the road on other jobs, so I found these at HF:
These ratchets if I had them would've made the job simpler with enough leverage to get the part installed. If you have these tools how do you rate them??
1/4 in, 3/8 in. Drive Long-Reach Dual Flex Head Ratchet
Amazing deals on this 1/4In, 3/8In Long Rch Dual Flex Head Ratchet at Harbor Freight. Quality tools & low prices.
www.harborfreight.com
1/4 in, 3/8 in. Drive Dual Head Ratchet
Amazing deals on this 1/4In, 3/8In Dr Dual Head Ratchet at Harbor Freight. Quality tools & low prices.
