Tallest marijuana plants I've ever seen....
If only.........lol . That shot is meTallest marijuana plants I've ever seen....![]()
Here. Try this.If only.........lol . That shot is me View attachment 130548giving that tropical itch again though . if only my budget agreed .
Looks like it was built by Studebaker...Pennsylvania Railroad 4-4-4-4 T1 Locomotive
In the late 1930s, Baldwin Locomotive Works (Baldwin) of Eddystone, Pennsylvania sought a partner to support the design of an experimental, rigid-frame, duplex, 4-4-4-4 locomotive. With this wheel arrangement, the engine would have a four-wheel leading truck, two independent sets of four-wheel drivers, and a four-wheel trailing truck. As a duplex engine, each of the four-wheel drivers would be powered by a pair of separate cylinders. Baldwin’s Chief Engineer Ralph P. Johnson believed the newly designed engine would be capable of improved efficiency that would rival diesel locomotives, which were just beginning to outperform steam. Compared to an articulated locomotive, a rigid-frame duplex arrangement created a comparatively light engine well-suited for high speeds. In addition, having four smaller cylinders with a reduced piston speed decreased wear and maintenance compared to two larger, harder-working cylinders as used in a standard locomotive layout, such as a 4-8-4. If not well-balanced, the reciprocating and revolving forces of the drive wheels on powerful two-cylinder locomotives could actually damage the track, an issue that was alleviated with a four-cylinder duplex.View attachment 130757
Or Tucker …..Looks like it was built by Studebaker...
The auto makers caught on to this....cover the engine with many shrouds and panels and make them hard to remove so ya have to go to the shop for maintenance.New York Central class J-1e 4-6-4 No. 5344 received sheet-metal shrouding in 1934, making it the first streamlined steam locomotive in America. Carl F. Kantola of NYC’s equipment engineering department created the design. The Hudson was named Commodore Vanderbiltafter the NYC’s famous early leader, but initially displayed no road number.
Glenn Grabill photoView attachment 130802
