Good morning,
As the completion date of the project gets closer we've moved onto gauges again and I needed to make a decision so I need to see if anyone out there can help me.
So we're going with a stand alone shift light on the A-pillar so it wil be just off to left line of sight.
But I wanted something for AFR and boost to amuse me.
AeroForce Interceptor seems to make a nice unit, two perameters displayed at once, flashing light warning, also can measure 0-60 and 1/4 mile times. But expensive, apparently close to $1000 to get the additional kits to measure boost pressure etc. Can be mounted in dash, A-pillar etc. I like the thought of having it also to the left on the A-pillar with the shift light though I've seen a dash install of Canuk's that looked very factory as well.
Dashtronix makes one as well, this uses either the radio display, which my car does not have, or the HUD display. Much less expensive but I'm not really enamored with the HUD as it is. Maybe this would get better with time?
So have any of you tried either of these units and would be willing to share your experiences.
Any other systems to consider that you've tried and found to be good??
Cheers,
Garry
Cheers,
Garry
