Great intro price on the A&A Supercharger Kits @ Dasilva Motorsports
C5 OR C6 KITS INSTALLED & TUNED $6891.50 + HST REG Price is $7100.00
+ Book before Sept 30th and recieve This $250.00 discount .
Note
•2006+ Z06 and 2008+ LS3 Z51 6-Speed Manual transmission cars, and 2010+ Grand Sport dry sump cars require a radiator upgrade. The new radiator will have provisions for the external oil cooler. New rad $875.00
DeWitts 2005-2008 Corvette (All Z06 & 07-08 Z51 w/ A6)
This Direct Fit radiator features two rows of 1" tubes, which doubles the cooling capacity of a factory single row. Our exclusive "press formed" end tanks are hand tig welded by expert craftsman, eliminating the factory plastic tanks. This radiator includes the correct factory type "quick connect" fittings for the transmission oil connections. Also used on 2007 Z51 cars with A6 transmission
This radiator is not to be used on a C6 Z06 with our supercharger kit. You will need the A05AE that has transmission and oil coolers.
Average increase TO THE REAR WHEELS is approximately 175 RWHP! No other modification, in this price range, even comes close.
A&A Corvette Performance is an independent manufacturer of custom supercharger systems for the C5 and C6 corvette, exclusively. Our systems have evolved into the most technologically advanced centrifugal systems available today.
With over 500 systems on the road and hundreds of additional hours spent analyzing how every part of the system could be potentially improved, it has evolved into the finest system available.
Look closely at our system vs. all others. The fit and finish of all components is second to none. This commitment to aesthetics carries forward in the same commitment to function.
Our bracket and pulley design offers excellent alignment and belt wrap. This is essential in any supercharger system and is unsurpassed by any other manufacturer.
Our intercooler design also differs from any other. Not only are our intercoolers as large as practical for a Corvette, but the placement and attention given to airflow management is unmatched. An intercooler must have as much ambient airflow through the core area as possible to be efficient. Our design is the only one that is 100% exposed to frontal airflow either directly (C6) or through the use of directional scoops (C5). Not one square inch of either intercooler is shrouded by the frame or bodywork.
Airflow through the rear of the intercooler is also important. Most designs place the intercooler tightly against the radiator and air conditioning condenser. We place our intercoolers with a large space between these components which aids in airflow through the intercooler as well as airflow to the radiator and condenser.
The inlet duct from our high flow air filter to the supercharger inlet is also designed with superior airflow in mind. The curves are smooth and cross sectional area is large. This all translates into lower inlet temps and more power output.
BOOK NOW & SAVE $250
Note
![ae6707832cc6059f47feb737b419ce35_image_300x208_zps06f87baa.jpg](/proxy.php?image=http%3A%2F%2Fi134.photobucket.com%2Falbums%2Fq88%2FC5vert%2Fae6707832cc6059f47feb737b419ce35_image_300x208_zps06f87baa.jpg&hash=5a3e587b62c394bf14eeaf946fad354a)
![999a77f5bc3f36a8d387155fb8ff4122_image_200x144_zps623adf9f.jpg](/proxy.php?image=http%3A%2F%2Fi134.photobucket.com%2Falbums%2Fq88%2FC5vert%2F999a77f5bc3f36a8d387155fb8ff4122_image_200x144_zps623adf9f.jpg&hash=a46a5797aa070fd6543b0c5106f75f5a)
![d2fa574442dc69042d15ed64b58d0efa_image_200x150_zpscc4a6093.jpg](/proxy.php?image=http%3A%2F%2Fi134.photobucket.com%2Falbums%2Fq88%2FC5vert%2Fd2fa574442dc69042d15ed64b58d0efa_image_200x150_zpscc4a6093.jpg&hash=ba8b0f958cbbd208bc2fc8770bea15fe)
