timminsguy
I'm New Here
Jun 28, 2014
6
Timmins
When I first start the car,.. odometer and speed appear normal ,.. when I release park brake the gauge lcd goes all scrambled,.. I apply the brake again its normal,.. if I turn the lights on it goes crazy again,.. thinking its a ground problem,.. my first vette and I just bought it ,... Lt1 6 speed standard ,... thanks for any help !
FIXED!!!!!! ,...(corrosion)(grounds)
Wow that is a strange one.
First I'd check for codes. Write them down as displayed for future reference.
The hardest part is shorting pins #4 and #12 at the ALDL. Use half a small paperclip.
Here is the procedure:
C4 Diagnostic Trouble Codes | CC Tech - Corvette Blog, Restoration and Repair
Second disconnect the battery for a few minutes so see if it resets the system.
Third, the grounding could be the issue, as you say. A quick google will show those points.
If none of that sheds any light then call Manny for advice. He's an electrical, as well as a mechanical, whizz.
g/l
Colin.
