60 Liter High Horse Power Diesel
Darrellg1
Active Member
You're 5 C4 You're a Regular You're Celebrated You're Celebrated You're Liked
1987 Corvette coupe,
about to get painted
@Darrellg1 think you might want to paint up one of these? A bit of traveling involved though. First ones a 3616 Cat pumping out about 3400 HP in Africa. Second one is a little ship main engine on our ship here in Indonesia. Can’t remember the HP.. in the 25,000 range. It goes down another 2 decks. Don’t much matter now as it only ballast. Won’t run again.
View attachment 26827View attachment 26829
Yepper been around them bugger too. here the main gear on the transmission of the coastal inspiration. HUGE!
Yepper been around them buggers too. Here's the main gear on the transmission of the coastal inspiration. HUGE! You can stand up in the oil pan it's so deep. It was over my head. Im 5'9"
A few pics from my yacht.
The engine control room showing one of the azipods.
Between the engines and the third is some of the cylinder heads for one of the engines.
I usually have around two thousand guests for an excursion. I don't charge anything as I leave that up to another company. LOL
I was truly lucky to get a private ship tour through all the operations systems/departments on one of the Holland America ships.
Nice clean boat Le Baron!...... i'm ex- Navy/Air Force, I appreciate a clean boat when I see it.
All facilities were spotless. Even the waste water is treated before being dumped overboard. First officer said it was drinkable. Unfortunately (or fortunately) the spigot was jammed.
