Ya, it's one in 100,000. I've heard sounds like that on mechanical lifters, but never on hydraulic lifters unless they are clogged. That should never be the case with a new car, but it could be a faulty lifter I suppose. However if a lifter is faulty you'd think you'd get piston slap. The LT2 is a zero interference motor.On the mechanical side someone suggested it might be a wrist pin noise. I have no idea what that would sound like. If it was an injector gone rogue that would be preferable I would think instead of having to tear down and / or replace the engine. Anyway, I guess we will find out when they take it apart (again) next week. These things can happen I know - although in all the years of owning motorcycles, cars, boats atvs etc... I have never had a mechanical engine problem to the extent that you would need to take it apart - not the least of on a brand new car worth $100K +.
No, but they could be related. If a lifter was clogged or "stuck" the valve spring would not operate properly. Hydraulic lifters need to be full of oil to work properly. If it can't get full it could cause noise as the rocker arm would knock on the valve stem and push rod.Sorry my ignorance, lifter stick same as valve spring issue?
Got it. Well they did replace the did replace the valve springs so maybe it's the lifter... I kind of doubt that though as they just had the top end off and they remarked how clean/normal everything looked. Anyway all I can do now is get them to expedite the service to find out what is wrong and either fix it or replace the engine. I'm suppossed to be driving it on the twisties in central BC right now instead of having it sit in a dealer's parking lot.....No, but they could be related. If a lifter was clogged or "stuck" the valve spring would not operate properly. Hydraulic lifters need to be full of oil to work properly. If it can't get full it could cause noise as the rocker arm would knock on the valve stem and push rod.
They don't need to remove the heads to replace the valve springs. They would have to remove the heads to replace a lifter.Got it. Well they did replace the did replace the valve springs so maybe it's the lifter... I kind of doubt that though as they just had the top end off and they remarked how clean/normal everything looked. Anyway all I can do now is get them to expedite the service to find out what is wrong and either fix it or replace the engine. I'm suppossed to be driving it on the twisties in central BC right now instead of having it sit in a dealer's parking lot.....
Oh I see. Well I'll post here once they find out the problem. Thanks for everyone's replies.They don't need to remove the heads to replace the valve springs. They would have to remove the heads to replace a lifter.
It’s fine . And are you sure that’s not a diesel in there ? Jesus you’re right it sounds like it going to go boom . The ticking sound that a lot of people hear , which in most cases does come from the injector system which operates at about 3,000 psi , isn’t what you are hearing. I feel for you and hope that it’s resolved quickly. At least you have warranty.Can someone let me know if the link is working. When I try to attach the file from my phone it is not working.
I just fired up an engine for the first time in about two years the other day and it was ticking loudly. Stuck lifter . After it ran for a few minutes and got some oil up there it let go and was purring like a pussy cat . 1968 350cid . But highly unlikely that is the cause of this clatter.No, but they could be related. If a lifter was clogged or "stuck" the valve spring would not operate properly. Hydraulic lifters need to be full of oil to work properly. If it can't get full it could cause noise as the rocker arm would knock on the valve stem and push rod.
Thanks. Ya who knows. My main concern is getting it fixed RFN. But if they have to replace the engine they said 4 weeks. F\___!It’s fine . And are you sure that’s not a diesel in there ? Jesus you’re right it sounds like it going to go boom . The ticking sound that a lot of people hear , which in most cases does come from the injector system which operates at about 3,000 psi , isn’t what you are hearing. I feel for you and hope that it’s resolved quickly. At least you have warranty.
By the sound of this crew first they’ll have to locate it , lol . Good luck.Thanks. Ya who knows. My main concern is getting it fixed RFN. But if they have to replace the engine they said 4 weeks. F\___!
It is.WOW not anywhere near the light tick in my C8…that is loud
