Hey I have a 09 ZR1 and I have a problem getting into 2nd gear , it grinds going into it . Every other gear is fine . Do I have a clutch issue or did I break something in tranny ? Any recommendations for a shop to take it to in Durham region ?
Oh and to add it is at any rpm
Thanks so much Brian it has 16000 km . I just checked that fluid it is black in colour and the level is just below the add mark. I will try to drain it tomorrow after work and replace the fluid . Keep my fingers crossed , I will let you know if it works . Thanks again Kevin
Well I tried but to no avail ? I added two 250 ml bottles probably about 20 flushes and took it out it will go into second if I'm stopped but from first to second it just won't go lots of grinding noise . First to third is fine as well as all other gears. ???
It sure look like internal problem Have you check at the dealer whit your serial number to see if there is any powertrain garanty left? If you are not the original owner, you may not know the date where the car was delivered. Not much to loose. Good luck
