My estimate of Cdn Z06 Pricing
No inside info here, but just believe that the relative differences in the pricing between the U.S. and Canada on Non Z51 and Z51, which seems to be +7.5% on the model + 5% on options, will likely carry into the final Cdn Z06 pricing.
Once GM Canada committed to the non Z51 and Z51 differential to the U.S. this is very likely to remain consistent for the Z06, otherwise this would mess up the relative value proposition.
I made up a spreadsheet on the 2015 Convertible to try and help myself decide the cost/benefit of staying non Z51, going to Z51 and now going into Z06 1LZ and then perhaps to 2LZ with Comp seat & Carbon dash options. It just does keep adding up, but at this stage, I am planning on waiting for the Z06, a 2016 by way of the Humberview Z06 Vert list.
The values assigned to the added specs that you get with the Z51 and Z06 are of course, not GM RPO codes but just an attempt by me to break down the value of each additional item in the packages. I did not spend a lot of time thinking about these assigned values but will do more once the Canadian pricing is out.
