feels like a syncros or alignment issue thoughIt's likely the 1st to 4th CAGS trying to work.
I ordered a CAGS eliminator the day I was made aware of it. Problem solved on my '17 Z.
right on thanks. you nailed it bang onThat's the CAGS. You get a visual on the dash / speedo. Shift from 1st to 2nd above 28kph or so, and it's fine. rpms over 3200 or so, it's fine, any less,, and it forces you from 1st to 4th.
Search here, or google, then order a CAGS eliminator. Less than $20.
yeah just need to run 1st a little longer....no biggie. actually even read about it in the manual tonight the 1st to 4th.....good to know.Strangely enough, I don't have the skip shift problem..... Drove manual tranny all my life so maybe it's the way I drive. My C6 had the granny skip shift too. The eliminater came with the car but I never found a need to install it. Still have it kicking round somewhere. That being said, and probably the reason why, but at 28kph I'm still in first gear anyway...
This feature was put in to help keep the vette out of the “gas guzzler tax” area. Don’t think I need 28k/hr to go to 2nd but if I felt the resistance I just went to 3rd. My c6 had a more intrusive setup but not enough to break up a factory setup.
