MotleyDrew
I'm New Here
2 You're 10
Nov 20, 2010
7
Ottawa
2001 Z06
Hello All
Time has come to part with my dream car. Unfortunately I am in a situation where I need to sell it as I do not want to. This car has the best of the best in it when it comes to parts and is in perfect working order. There really is not another one like it in Canada. I have invested over $100,000.00 dollars into this vehicle not including what i paid for the car initially. This car can be driven as a normal everyday car if one so wishes. It is both docile and retardedly aggressive as that was my goal. There is only about 6000km on the drive train and 42,000km on the body of the car. It is a real 2001 Z06. Nothing has not been upgraded in this vehicle.
This car is a steal at what i am selling it for. Please only inquire if you are serious. Car can be seen and run any time for potential buyers.
thanks and click on my garage for the complete list of modifications :)
The car has been featured twice as seen in the links below:
Vortech Article:
Drew Cameron's Z06 | Vortech Superchargers
Planet LSX Article:
Sinister - PlanetLSX
$45,000.00 cdn
please email - [email protected]
Engine/Drivetrain Modifications:
403ci A&A Corvettes Forged and Stoked Aluminum Block LS2 Motor
4.005" bore 4.00 stroke
-14cc Dish Forged Manley Pistons
Forged Eagle Crank
Skat 6.125 rods
Hellfire" rings
ARP Main Studs
Clevite Bearings
Ported Oil Pump
Springs Dual Patriots
Comp Cams Cromolly Hardened Pushrods
RPM modified Rockers
Cam is a custom ground blower Comp Cams
Roll Master Double Timing Chain & Gears
9:6.1 Compression
Edelbrock Aluminum 215cc CNC milled by West Coast Racing Cylinder Heads 74cc
Innovators West Custom 8” Balancer SFI SPEC 18.1
A&A Billet Aluminum MAF Scattershield
Custom Painted Valve Covers/ Fuel Rail Covers by Ottawa Valley Custom Paint
RSI Twin intank 255lph Fuel pump
RSI Fuel Rails
-6 Braided Steel Fuel Lines throughout
80lb Ford Racing Injectors
A&A Cooling Mist Progressive Methanol Injection Kit
MSD 8.5mm Ignition Cables
Optima Red Top Extreme Duty Cycle Battery
NGK TR7 Iridium spark plugs (0.035" gap, two steps colder)
A&A Vortech YSI-Trim Supercharger Kit
A&A Intercooler
Polished Mondo Vortech Bypass Valve
A&A 8 rib pulley setup
Catrek Flip Drive System
A&A belt tensioner system
K&N Valve Cover Breather
Crilly Chassis Works Custom Intercooling Piping and other modifications
Dewitts High Capacity Aluminum Radiator
Dewitts Twin Spal Fan Aluminum Shroud
180 degree thermostat
A&A Air Filter
Throttle Coolant Bypass
Air Flow hood lip liner
American Racing Long Tube Headers Ceramic 1 7/8 Headers
Matrix Hi Flow Catalytic Converters
American Racing X Pipe and 3"extention pipes
Billy Boat Bullet Cat Back
GM C6 Z06 Big Brake Kit
Hawk Ceramic Brake Pads
Cartek Line Lock-Kit
DTE Transmission/Rear End Strut Brace
ACT Extreme Twin Disk Clutch
B&M Precision Shifter
Column Lock Bypass
CAGS Skip shift Eliminator
Stock 3:42 Rear Gear
HP Tuners Pro MPVI Tuning Software
Innovator Motorsports LC-1 Wideband
Transmission / Clutch:
RPM Level 5 M6
carbon syncros
billet keys
bronze pads
steel shift fork
cryoed gears
cryoed 30 spline output shaft
Advanced Clutch Technologies Extreme Twin Disk Clutch and Billet Steel Flywheel ACT Twin T2S-G01 950lbtq
Column Lock Bypass
Adjustable Tick/Tilton Master Cylinder
Rear End:
RPM Level 5
3 rib HD Z06 case
Billet alum pinion support
300M left output shaft
300M right output shaft and spider gear
HD Carbon clutch packs
HD clutch springs
Cryoed 3.42 Gear
30 spline gears
Suspension Modifications:
Stock Z06
Bilstein Sport Shocks
Lowered 2 inches
Aluminum Suspension End Links
Wheels/Tires Modifications:
iForged TE-7 Powdered Coated Black
19 X11"
18 X 10"
Interior/Exterior Modifications:
Stock Z06 Black
22 % Tint on All windows
Shorty Antenna
Custom Z06 1000hp badging
So...I guess your not interested in a trade with a stock 2000 coupe? I'm even willing to trade straight up:D
Sorry to hear you have to sell it. Hopefully it will sell for you quickly and you'll be in something new in no time after that. Beautiful car! I wish I had the money.
amazing. Tons of things rushing through head, will reserve gushing comments.
A local guy with a fordgt, ford said with 900hp, that he would need 4 fuel pumps. If you want to talk offline or in another comments section, about your driveability, etc, would probably do you a world of good. I just can't even imagine it, how does it hold together, what gear would you get traction, etc, etc, etc.. What an awesome looking ride. I wish you well. Things are tough to sell in the US, but I saw a guy sell a monster down there.
Hey bud
The guy with the Ford GT is incorrect as you cAN FEED OVER 1000HP WITH ONLY ONE PUMP IF ITS THE CORRECT PUMP. tHE 2 INTANK 255LPH PUMPS and 80lb injectors IN THIS CAR ARE MORE THAN ENOUGH. fULL THROTTLE TRACTION IN 3RD CAN BE AN ISSUE EVEN AT 160km :)
I was hoping you would have posted here saying "sold" as I want our site to be successful for people. However, another part of me wants your car to stay on the market for the next 5 years as that should be about when I'll have enough saved up to buy it.:D
