I read that they have 30 engine builders. I think each builder can easily build 2-3 engines per dayAnother thing I thought of is how many engine builders there are.
They would need 60 engineers building 1 engine each per day.
It's likely doable, but I wouldn't want to stretch it.
Easily? Does that include the testing etc.? I can see maybe 2, but I'm assuming everything on the engine. Including alternator etc. Do pistons arrive to the engineer with the rings on them? etc. etc.I read that they have 30 engine builders. I think each builder can easily build 2-3 engines per day
I don't think builders are the ones testing the enginesEasily? Does that include the testing etc.? I can see maybe 2, but I'm assuming everything on the engine. Including alternator etc. Do pistons arrive to the engineer with the rings on them? etc. etc.
4 guys build 2 engines in 17ish minutes...30 guys should be able to build 15 engines in 20 minutes easy...thus in an 8 hour shift = 45/hour x 7 hr shift (giving time for lunch and a couple pee breaks) = 315/shift conservatively. Thats 255 more engines than cars built....No Sweat.
That would be awesome!I hear that z06 production has been increased by 27% from 60 cars per day to 77 cars per day.
What’s the maximum number of Corvettes (of any kind) that can be built in one day? According to Murray’s posts it seems to be just shy of 190. So will Stingray numbers drop comparably to the Z06 production numbers?
Yes, Stingray production will drop. I'm not sure if I'll get numbers separately or not, but time will tell.What’s the maximum number of Corvettes (of any kind) that can be built in one day? According to Murray’s posts it seems to be just shy of 190. So will Stingray numbers drop comparably to the Z06 production numbers?
I'm told not.I know they have some Covid cleaning in between shifts but what if that cleaning gets reduced or remove...Could they have a 3rd shift?
That is more in keeping with what I thought.New info coming in: each engine builder is given roughly 3 hrs to build 1 engine, so 2 engines per 8hr shift
