I have a 2017 Grand Sport with the Z07 pkg on it and was thinking about getting the Mild2Wild module for the exhaust NPP valve, any reviews on that?
I considered this as well but didn't see any real advantage for me anyway. In track mode all the valves are open all the time anyway. I didn't want to run in full track mode all the time so just went into my Settings on the touch screen and to Engine sound settings. There you can set the sound to Track mode and your valves stay open all the time no matter what driving mode you are in. Want it quiet again? just go back in and change the sound accordingly. The only thing the Mild to Wild gives you that I can see is having a button to press instead of a couple entries on the touch screen. JMOI have a 2017 Grand Sport with the Z07 pkg on it and was thinking about getting the Mild2Wild module for the exhaust NPP valve, any reviews on that?
I have read that with that option the exhaust will only open when starting and when the throttle is at 80% and rpm is above 3500. That is why I was wondering if i should use that module. Any experts out there that can verify this?I considered this as well but didn't see any real advantage for me anyway. In track mode all the valves are open all the time anyway. I didn't want to run in full track mode all the time so just went into my Settings on the touch screen and to Engine sound settings. There you can set the sound to Track mode and your valves stay open all the time no matter what driving mode you are in. Want it quiet again? just go back in and change the sound accordingly. The only thing the Mild to Wild gives you that I can see is having a button to press instead of a couple entries on the touch screen. JMO
My engine sound management is set to 'Track' and my exhaust is valves open track sound all the time and at all rpms. Maybe that makes me an expert?I have read that with that option the exhaust will only open when starting and when the throttle is at 80% and rpm is above 3500. That is why I was wondering if i should use that module. Any experts out there that can verify this?
Correct. Setting it to Track does not mean the valves are open all the timeI have read that with that option the exhaust will only open when starting and when the throttle is at 80% and rpm is above 3500. That is why I was wondering if i should use that module. Any experts out there that can verify this?
Welcome to come out and have a look up mine anytime.Correct. Setting it to Track does not mean the valves are open all the time
Easiest way to do that is the pull the fuse that controls the valves. Then it stays open all the time. Dont need some fancy device. Yank the fuse and put it back in if you dont like it but I am assuming you will! Havent even considered putting the fuse back in over the past 2 years
Cant remember the fuse number but do a search as lots of threads on this here and on the other forum
Of course, thank youWelcome to come out and have a look up mine anytime.
I thought I had read that if you pull the fuse it throws a codeCorrect. Setting it to Track does not mean the valves are open all the time
Where are you located?As others noted, even in track mode, the NPP valves close in certain conditions. I played around with pulling the fuse but eventually got the Mild2Wild so I had the option to keep it quiet. Happy I got it. Ended up getting another one for someone else, but theirs is a 2014 and it doesn't work as well on those years (due to lack of stealth mode....it's complicated). Might sell it if you're interested.
Hmmmm, I have never read that but in any event, no codeI thought I had read that if you pull the fuse it throws a code
I guess I have been corrected.Of course, thank you
Doesn't change the fact that the valves do not stay open all the time, which seems to be your implications
Where are you located?Welcome to come out and have a look up mine anytime.
Sitting in my easy chair in Alberta...Where are you located?
I pulled the fuse on my 2017 it is fuse #42 and the car sounds amazing I think i will keep the fuse out for the time being!Correct. Setting it to Track does not mean the valves are open all the time
Hey do you have any video of the exhaust now? Looking to do this to my 2019 c7. I want to do a 2nd cats delete so I can keep the npp muffler/exhaustIt's in the glove box if ever needed but not seeing a pass through of Edmonton any time soon
It doesn't make it any louder really. The thing that made mine louder was cutting out the secondary cats in the x-pipe. Nice sound improvement for little cost!
