Hey folks. I’ve got almost 20k on my car and I think it’s time to change the DCT filter. For anyone that’s done it where did you buy the filter and did you add the 2 extra quarts to the tranny?
Thanks
Thanks
You know you are supposed to flush the system when you change the filter right?Hey folks. I’ve got almost 20k on my car and I think it’s time to change the DCT filter. For anyone that’s done it where did you buy the filter and did you add the 2 extra quarts to the tranny?
Thanks
Thanks
Thanks
For anyone not aware it's a procedure that circulates all the DCT fluid through the filter once (at least?)
Anyway, I'm pretty sure it can't be done at home, though I'm also not sure how necessary it is.
I paid $275 plus HST for transmission flush and filter change (included one liter of trans fluid). 1.9 hours to do trans flush and filter change.I didn’t realize. Ok thanks Murray. I was quoted $650 to change the filter and $995 for the transmission service. I was blown away.
Just to be clear, I was quoting the labour only to do the trans flush and change the filter, plus one liter of trans fluid. I had bought the trans filter online for $135 and took that to the dealership.That is an incredible deal , the filter alone lists for $260
Guys, can you please point me at the DCT filter at Genuine GM Parts & Accessories in Canada | Kipp Scott GM Parts? Even by saying corvette 2021 I can't find it.
Also at 12000KM it's only a filter change, correct?
At what KM you have to do a transmission oil flush also?
Here is my order from Kipp ScottGuys, can you please point me at the DCT filter at Genuine GM Parts & Accessories in Canada | Kipp Scott GM Parts? Even by saying corvette 2021 I can't find it.
There is a trans flush procedure required at 12,000 that does not include replacing the trans fluid, only running it through the filter. This requires manipulation of the trans control unit to open the proper valves during the flush, so it generally has to be done by the dealerAt 12,000 km it's a filter change although Murray says they should also do a full flush but then Driver_WT in post #10 above said his dealer only put in a litre of transmission fluid. On another Corvette Forum I've seen others describe only putting in the filter and replacing what little fluid escapes (much less than a litre) from doing that.
Ya, like @Driver_WT said. You'd think the fluid is continually cycling through the filter so I'm not sure how important it is, just that that is the procedure outlined by ChevroletAt 12,000 km it's a filter change although Murray says they should also do a full flush but then Driver_WT in post #10 above said his dealer only put in a litre of transmission fluid. On another Corvette Forum I've seen others describe only putting in the filter and replacing what little fluid escapes (much less than a litre) from doing that.
Yes, the only thing I will add is that the trans flush procedure at 12,000 km's is a recent recommendation from GM due to some dirt contamination in the transmission which has the potential to get into the trans valves and cause a trans error code and possibly malfunction. I believe there is a TSB for the trans flush procedure.Better then manual:
-when doing a Trans Canister filter replacement, also ask to do a transmission flush... I guess to clean the oil and put it back in the transmission... this procedure will require to top off the trans fluid because some is lost in the process.
Is my understanding good?
Makes one wonder just how often the fluid does cycle through the filter. Perhaps it just does it periodically at some defined period.Yes, the only thing I will add is that the trans flush procedure at 12,000 km's is a recent recommendation from GM due to some dirt contamination in the transmission which has the potential to get into the trans valves and cause a trans error code and possibly malfunction. I believe there is a TSB for the trans flush procedure.
