@ddgermann Ive had issues with over heating, although there are many solutions from others I think first step is to change the engine oil to something meant for track.
I do not know of a better oil for the Z06. Perhaps some of the other guys have an oil they prefer.
I agree that putting in the best oil for the heat is the right first step.
@Wilbergz. This is a hot subject (pun intended)... You will find a different answer and solution around every corner. Which is the right answer? If you strike upon it, let the rest of the world know please. The latest has been run 0-40 Mob 1 and you should be good to 280 F. And change your oil at the 50% mark as a minimum depending on how often you track your car.
Quick phone call ... Spring Mountain - Ron Fellows Program ... see if they have a tech that may be very helpful ....
(although please know that they set up cars differently for different uses in the Corvette Owner School - might not with the Mobil 1 though)
