I know beans about this, so explain to me how is the exhaust designed to open up ? Don't tell me about remote control buttons. Is there a seperate exhaust pipe ? , split pipes with one by passing the muffler going straight through open and closed by a butterfly ? I wanna know what is under the car ? In the old days a guy just took off the header plugs , this just sounds like same type of deal only fancy way of doing it.
I'm late to this, and Pep's video shows the difference in sound and explains it a bit, but doesn't really get into it. I think I've delved into this in another thread, but whatever, this is the Interballs.
Essentially, the pipe comes into the muffler and Y's through the canister. One side is baffled and quiet, the other is not exactly straight-pipe, but certainly much-less baffled. This is the one that has a butterfly. When it is closed, the back-pressure will cause the exhaust to go out the baffled and more quiet side. When it is open, it will flow through both sides, although one is much better than the other, and does make a really neat noise from that perspective. Both muffled and open at the same time - It really is a cool sound.
The factory system is vacuum-actuated on the early systems (I think C7's are electronic and based on rpms and throttle position), and the Mild-to-Wild system is electronic, based on what you want and when you want. With the M2W, you can have it open at idle, or all the damn time if you want to, whereas the stock NPP system is based on how hard you are on the throttle.
It is quite simply the next step of evolution in electric cutouts, while being able to maintain emissions. Classic aftermarket options being implemented into modern engineering and yet still meets all EPA and other regulations.
