Looner25 Casual User 2 You're 10 Sep 15, 2013 11 12 Grimsby, Ontario VetteCoins 678 Car 1995 Polo Grn Coupe Sep 29, 2019 #1 Replaced the water pump today car seemed fine but after stopping I could hear bubbling(boiling water) in the tank......?..
Rruuff Day Staff member Power User Moderator Beta You're 5 Aug 30, 2014 15,095 21,125 VetteCoins 21,940 Sep 29, 2019 #2 Looner25 said: Replaced the water pump today car seemed fine but after stopping I could hear bubbling(boiling water) in the tank......?.. Click to expand... May have been air locked... Did you bleed the air out when you refilled? Reactions: turbozig and LE BARON
Looner25 Casual User 2 You're 10 Sep 15, 2013 11 12 Grimsby, Ontario VetteCoins 678 Car 1995 Polo Grn Coupe Sep 29, 2019 #3 Rruuff Day said: May have been air locked... Did you bleed the air out when you refilled? Click to expand... Exactly was it was... Reactions: turbozig, OL Yeller, 12cents and 3 others
VikingTrad3r Regular You're 5 Sep 9, 2014 345 354 VetteCoins 6,335 Oct 2, 2019 #4 it will take a few cycles of heating up and cooling to be void of all gas in the system. just keep adding the coolant to the overflow
rvguy79 Casual User You're 5 Nov 22, 2014 58 36 Pickering Ontario VetteCoins 1,357 Car 1993 C4 Dec 19, 2019 #5 LT1 has a reverse flow cooling system to direct coolant to the cylinder heads first to support the higher compression of the LT1. There is a “burping” procedure to follow to get the air out. You can find it online. Reactions: RockyPM
