How many of you are finding the tire pressure monitor wonky ? My front tires always show the same pressure and the rear’s are different from each other and the fronts by 10 to 12 kpa or so. I adjusted the pressure of all of them to the factory recommended 30 psi as they were anywhere from 32 to 36 on delivery. All season stock tires. Does seem that the run flats which are noisy to begin with aren’t quite so annoying and the vehicle does seem to ride a bit better, not as jarring on expansion joints or ridges in the road surface etc after going down to 30 psi . This vehicle has mag ride . I used two different gauges to check the pressure and both showed 30 bang on with the tires at ambient temperature.
