I have a 2004 C5 & the driver side flashes dash, passenger side flashes normally but all of the bulbs light, none are burned out. Where is the flasher located on a 2004 C5? Also what is a “stalk”?
Yes. That's where the flasher is. There are You Tube videos on how to get at it. Be prepared. It is a mayor PITA to get at.Hi. The stalk is your turn signal lever (and all the other contols on it). Until a C5 expert chimes in and corrects me, I think the signal flasher is up under the dash behind the 4 way flasher switch.
I had the same issue recently and replaced the Hazard Switch. Working Great now
