I did find this mod that ‘some’ claim works to pop the trunk .
I have not tried this.
Simple fix without attaching the large spring. Take off the rear center carpeted section that covers the lock mechanism. Next to and slightly in front of the latch there will be a spring with about 1 1/2" extended out with a slight bend. This is the piece that pushes the lid up. With closing and age that piece of spring that sticks out begins to bend downward.
Put pliers to it and bend it back up so it extends above the latch mouth.
The amount you bend it is the amount the trunk lid will raise.
Real easy fix and you can get rid of the spring you added to the lid.
There is also a spring popper you can order.
GLOCKPLATES has a spring to add-on.
Some blogs say you can purchase a spring from HomeDepot that does the same.
good luck
graham
