Looking for a roof or just the shell, seeing if anyone has one they'll never use before I order one next week
Be aware of buying used as I have been told the C7 transparent roof is different from C7-2014 thru to part of C7-2016
and then it changed from mid C7-2016 thru to now ... I have a mid C7-2016 and wasn't able to use one from a C7-2015
that I found on Kijiji ... So you should post your C7 production date too. If you have a C7-2016 you might want to do a fit before buying.
Dang itThe difference is the pins and receivers. Assuming you are driving an earlier C7, in Mid 2016 they were changed to larger pins due to rattle complaints. (The white pins I believe) There is a kit to upgrade available if you buy an older roof for a mid 2016 car or newer or vice versa. Tons of good info on this if you search a bit around with Google. I just bought a mint used clear roof for my Z from Frank so I went through the process of identifying the differences. The roof is on my car now and it fit like a glove.
I have all the hardware from my 15, just scratched the outside! Dealer quoted me 1000 for the shell, but I'm sure there's places that would be cheaper
