tape foam adhered to it so that the back of the plate cant scratch the surface of the grille. How is your front plate fastened?
Sorry Paul. Can't add much here as my front plate and plate holder are on a she
I would avoid the use of tape and just run the risk myself....
We are spared the hideous front plate in SK too. Oddly enough I've never had a problem in BC. All my cars run SK plates, so if I ever do get pulled over I'm just going to play dumb I would avoid the use of tape and just run the risk myself....
I'm pretty sure BC or any other province couldn't make a missing front plate ticket for out of province registered vehicles stick anyway. For one, since 1991, unless it's a vanity plate, we are only issued one licence plate in Alberta ...
Oddly enough, In all the years that I have been doing this never had a problem with automotive 2 way tape. The plate on my T-Bird has been on there since 2002. When I need to remove a plate I use a heat gun on low setting and slowly with a plastic putty knife work my way through it. Then some Goop Off and in 10 mins its done. The prob with the vette is mounting with tape to the grille would be risky as the grille does not offer a solid service. I think I am going to get some white zap straps and swap out the black ones.... should blend in better. Nice Sunny day here but only 5 degrees, tempted to take car out for a spin.,...
There are some nice low profile front plate holders for your car. They snap right in and actually look pretty good.
Quick search finds one. I’ll look for you tomorrow if your interested.
Derek
Thanks for the offer Derek. I think the plate holder you're talking about is a very good alternative to the stock GM one. But its still designed for a full plate, Not sure If it could be cut to allow for mounting a cut narrower plate. A thing british plate would not look as bad as our plates mounted tot the front
Maybe Paul you are going to have to find a Rubbermaid product and cut out a custom piece that fits your plate.
Don’t laugh I did this on some of my sleds to handlebar mount the EGT and race packs. Light and flexible. It looked great too. People would ask where I got the flexibile mount and have to look real close before they would believe it was a chop out part of a garbage can lid.
Guys these are special cars. I know the MSRP on mine was $127,500...are we really doing stuff like this? I'm all about "rigging" where necessary, but......really???
I noticed a mark this year when I had to remove plates to cancel insurance: I will put piece of black tape on back of LP bracket this spring - no problem front.tape foam adhered to it so that the back of the plate cant scratch the surface of the grille. How is your front plate fastened?
