R
ray
Member
Feb 23, 2010
33
Awards
2
hamilton
2009 coupe
gettting warning on hiway right front tire pressure high check readings left front is 242 right front is 288 what gives should i switch to nitogen
not2melo
not2melo
High RPM Poster
Feb 8, 2009
1,199
Awards
3
Greg in Toronto/Gtown
1999 C5 Z51
242kpa = 35psi
282kpa = 41psi
The over pressure tire sensor system on the vette trips off around 42psi.
Try reducing your tire pressure to 227kpa or 33psi as when the tires get
warm/hot on hwy driving the pressure will increase a few psi.
Nitrogen helps with the tire pressure swinging low and high and will also
help if your tires leak in the early spring when the temp ranges go from
low to high during the day and night.
I added Nitrogen to my tires last summer and would not add air again.
not2melo
not2melo
High RPM Poster
Feb 8, 2009
1,199
Awards
3
1999 C5 Z51
No problem, any question you have post them up and we will try to give you the most
imformative information to help you out.
not2melo
not2melo
High RPM Poster
Feb 8, 2009
1,199
Awards
3
1999 C5 Z51
A rapid, persistent chemical reaction that releases heat and light, especially
the exothermic combination of a combustible substance with oxygen. :D
Creedence85
Replies
2
Views
803
*ZR01#
Mach147
Replies
14
Views
970
C8 Forum
Dave Evans
D
C
Replies
12
Views
863
C
M
Replies
Views
314
M
